poISCL GetNumberOfPoints
Gets the number of points on the Stress Characterization Line (SCL).
poISCL_handle GetNumberOfPoints
HyperView Tcl Query
This command returns the number of points on the Stress Characterization Line (SCL). The beginning and end points are included.
To get the number of points on the Stress Characterization Line (SCL):
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_ctrl
result_ctrl GetStressLinearizationCtrlHandle stresslin_ctrl
stresslin_ctrl GetSCLHandle scl_handle scl_id
scl GetNumberOfPoints
hwi CloseStack
None.
