poIScaleCtrl GetScale
Gets the scale for X, Y, and Z.
poIScaleCtrl_handle GetScale
HyperView Tcl Query
This command returns the scale for X, Y, and Z.
None.
View new features for HyperWorks Desktop 2021.2.
Gets the name of the nodal vector result that is used for animation.
Gets a list of datatypes suitable for animation.
Gets the scale mode.
Gets an analysis system number.
Sets a specified data type as a new source for animation.
Sets the scale mode.
Sets the analysis system.
Sets the scale for the XYZ axis.
HyperView Tcl Query
None.
