poIResultMathCtrl RemoveExpression
Removes an existing result math expression.
rmath_handle RemoveExpression id
HyperView Tcl Modify
This command deletes/removes an existing result math expression. If there is a data type corresponding to this expression, the data type will also be deleted.
- id
- The ID of the expression to be deleted/removed.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
set mid [client_handle AddResultMathAnalysis “c:/samples/bumper/d3plot” “c:/samples/bumper/d3plot”]
client_handle GetModelHandle model_handle $mid
model_handle GetResultCtrlHandle result_handle
result_handle GetResultMathCtrlHandle rmath_handle
set eid [rmath_handle AddExpression]
rmath_handle RemoveExpression $eid
hwi CloseStack
Returns a non-zero value if there is an error.
