poIResultCtrl RemoveSimulation
Removes the simulation reference from the current subcase.
poIResultCtrl_handle RemoveSimulation simulation_index
HyperView Tcl Modify
This command removes the simulation reference from the current subcase.
Note: RemoveSimulation will fail if the current subcase is not a derived subcase.
simulation_index
The simulation index to remove.
To remove a simulation:
set dsub_id [rctrl AddSubcase "Derived_Subcase"]
rctrl SetCurrentSubcase $dsub_id
rctrl AppendSimulation 1 0
rctrl AppendSimulation 1 1; #this will be removed
rctrl AppendSimluation 1 2
rctrl RemoveSimulation 1
Returns the hwResult.
