poIQueryCtrl GetDataSourceProperty
Gets the value of the specified property for a given source.
poIQueryControl_handle GetDataSourceProperty source property
HyperView Tcl Query
This command retrieves the value of the specified property for a given source.
Note: To be able to retrieve a property value, it should be set before by using poIQueryCtrl SetDataSourceProperty.
source
The source for which the property is sought.
property
The property of which the value is sought.
To get the corners property of node:
mySessionName GetProjectHandle myProjectName
set pageIndex [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $pageIndex
set windowIndex [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $windowIndex
myWindowName GetClientHandle myPostName
set modelIndex [myPostName GetActiveModel]
myPostName GetModelHandle myModelName $modelIndex
myModelName GetQueryCtrlHandle myQueryName
myQueryName GetDataSourceProperty node corners
Returns the data source property, or an error code (HW_InvalidHandle) if the handle used to invoke the method is no longer valid.
