poIPartAssembly GetColor
Gets the part assembly color as an RGB value.
poIPartAssembly_handle GetColor
HyperView Tcl Query
This command retrieves the part assembly color as an RGB value.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetPartAssemblyHandle part_assembly_handle 1
part_assembly_handle GetColor
hwi CloseStack
Returns an empty string if an error occurs.
