poINote SetPosition
Sets the note position.
poINote_handle SetPosition location
poINote_handle SetPosition {x_pos y_pos}
poINote_handle SetPosition {x_pos y_pos z_pos}
HyperView Tcl Modify
This command sets the note position.
This command has two possible argument types:
Two value list: used with the "screen" position type (see poINote::SetPositionType)
x_pos:
The x coordinate on the screen; value between 0 (left) and 1 (right).
y_pos:
The y coordinate on the screen; value between 0 (top) and 1 (bottom).
Three value list: used with the “coordinate” position type (see poINote::SetPositionType)
x_pos:
The x coordinate in model coordinates.
y_pos:
The y coordinate in model coordinates.
z_pos:
The z coordinate in model coordinates.
To position a note at the top left corner of the modeling window:
poINote_handle SetPosition 0 0;
poiPost_handle Draw;
To position a note at the center of the modeling window:
poINote_handle SetPosition 0.5 0.5;
To position a note at the model center:
poINote_handle SetPositionType coordinates
poINote_handle SetPosition 0.0 0.0 0.0
Returns 0 if successful, otherwise an error code.
