poIMeasure GetValueList
Gets a list of values for all items in the measure.
poIMeasure_handle GetValueList name
HyperView Tcl Query
This command retrieves a list of values for all items in the measure.
- name
- The measure component name. Options include: mag, x_comp, y_comp, z_comp, scalar, and subcase.
Context
Elemental/Nodal Contour Example
m GetValueList or m GetValueList Scalar | |
Value checked or unchecked | {contour_value} In case of top/bottom {contour_value@Top_layer_name contour_value@Bottom_layer_name} |
Value checked or unchecked | {Contour_value corresponding_Layer_name} |
Value and subcase both checked | {Contour_value}
{Subcase_internal_ID} |
Value checked and subcase unchecked | {Contour_value} |
Value unchecked and subcase checked | {Subcase_internal_ID} |
Value and subcase both unchecked | {Contour_value}
Value and subcase both checked | {contour_value@Top_layer_name Subcase_Internal_ID contour_value@Bottom_layer_name Subcase_Internal_ID} |
Value checked and subcase unchecked | {contour_value@Top_layer_name contour_value@Bottom_layer_name} |
Value unchecked and subcase checked | {Subcase_Internal_ID Subcase_Internal_ID} |
Value and subcase both unchecked | {contour_value@Top_layer_name Subcase_Internal_ID contour_value@Bottom_layer_name Subcase_Internal_ID} |
When a Derived Loadcase is made current, two additional options are made available in the Contour panel that correspond to the Envelope Trace Plot: Subcase and Simulation.
If either Subcase or Simulation is selected from drop-down menu, when m GetValueList is invoked from the command line, it reiterates what is displayed on the screen. The values with Layer names in the case of Top/Bottom.
When m GetValueList subcase is invoked in the above two cases, the output is {}.
Incremental Angle/Relative Angle/Angle Between Example
m GetValueList
(When all are either checked or unchecked) |
{X-projection Y-projection Z-projection True_Angle} |
m GetValueList (When more than 0 options are checked) |
All the corresponding entries on m GetValueList. |
m GetvalueList Mag | {True Angle}, irrespective of whether the True Angle check box is checked or unchecked. |
m GetvalueList x_comp | {X-projection}, always displays x_comp, irrespective of whether the X-projection check box is checked or unchecked. |
m GetvalueList y_comp | {Y-projection}, irrespective of whether the Y-projection check box is checked or unchecked. |
m GetvalueList z_comp | {Z-projection}, irrespective of whether the Z-projection check box is checked or unchecked. |
Distance Between/Relative Displacement/Incremental Distance Example
m GetValueList
{X Y Z Magnitude} |
m GetvalueList Mag | {Magnitude}, irrespective of whether the Magnitude check box is checked or unchecked. |
m GetvalueList x_comp | {X}, irrespective of whether the X-projection check box is checked or unchecked. |
m GetvalueList y_comp | {Y}, irrespective of whether the Y-projection check box is checked or unchecked. |
m GetvalueList z_comp | {Z}, irrespective of whether the Z-projection check box is checked or unchecked. |
Position Example
m GetValueList
{X Y Z} |
m GetvalueList x_comp | Always displays x_comp, irrespective of whether the X-projection check box is checked or unchecked. |
m GetvalueList y_comp | Always displays y_comp, irrespective of whether the Y-projection check box is checked or unchecked. |
m GetvalueList z_comp | Always displays z_comp, irrespective of whether the Z-projection check box is checked or unchecked. |
Error
Returns 0 if successful, otherwise an error code.
