poIIsoValueCtrl SetEnableState
Sets the auto load/unload iso value data state.
poIIsoValueCtrl_handle SetEnableState state
HyperView Tcl Modify
This command the auto load/unload iso value data state.
Note: Setting enable state to false causes the currently loaded data to be unloaded.
state
True if the iso value data can be loaded, false if it cannot.
Returns 0 if successful, otherwise an error code.
