poIImagePlane GetTrackerColor
Gets the RGB values assigned to the video tracking marker.
Imageplane_handle GetTrackerColor
HyperView Tcl Query
This command returns the RGB values assigned to the video tracking marker.
To determine what color the video tracking marker is set to:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetImagePlaneCtrlHandle ipc_handle
ipc_handle GetImagePlaneHandle image_plane_handle 1
image_plane_handle GetTrackerColor
hwi CloseStack
Returns HW_InvalidHandle if the image plane handle is invalid.
