poICrossSectionSet GetIType
Gets the IType value of the cross section.
poICrossSectionSet_handle GetIType
HyperView Tcl Query
This command retrieves the IType value of the cross section.
None.
View new features for HyperWorks Desktop 2021.2.
Gets the entity set information of the cross section for a given entity type.
Gets the cross section ID.
Gets the ITypeID value of the cross section.
Gets the cross section label.
Gets the type of cross section.
Gets the cross section visibility state.
Sets the cross section visibility.
HyperView Tcl Query
None.
