poIContourCtrl SetValueFilterEnableState
Sets the state of the contour value filter.
contour_handle SetValueFilterEnableState state
HyperView Tcl Modify
This command sets the value filter state for the contour.
state
The boolean value to set the value filter state (True or False).
To set the value filter state for a contour:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle GetContourCtrlHandle contour_handle
# Sets the value filter state to true
contour_handle SetValueFilterEnableState true
hwi CloseStack
Error
Returns an error if the value state cannot be applied.
