poIComponent GetAssemblyID
Gets the assembly ID of a component.
Important: Please note that this command has been deprecated and therefore is not recommended for use. See the poIPart Class for an alternative command that can be used.
poIComponent_handle GetAssemblyID
HyperView Tcl Query
This command returns the assembly ID of a component.
To get the assembly ID of a component:
mySessionName GetProjectHandle myProjectName
set pageIndex [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $pageIndex
set windowIndex [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $windowIndex
myWindowName GetClientHandle myPostName
set modelIndex [myPostName GetActiveModel]
myPostName GetModelHandle myModelName $modelIndex
myModelName GetComponentHandle myComponentName 1
myComponentName GetAssemblyID
Error
Returns the assembly ID of the component, or an error code (HW_InvalidHandle) if the handle used to invoke the method is no longer valid.
