poICFD GetStreamLineDecimation
Returns whether decimation is being applied to streamlines in the CFD Plot/Streamlines panel, in order to reduce the memory footprint.
poICFD_handle GetStreamLineDecimation
HyperView Tcl Query
This command returns the setting specifying whether or not decimation is being applied to the streamlines obtained by the integration process. Decimation will effectively reduce the memory footprint and improve graphic performance afterwards, however it is important to note that the streamlines could become less smooth and decimation process itself takes some time.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle GetCFDCtrlHandle CFD_handle
hwi CloseStack
Error
Returns false if no integrator exists.
