pltIBuildPlotsCtrl SetLegend
Sets whether the legend is on.
pltIBuildPlotsCtrl_handle SetLegend legend_on
HyperWorks Tcl Modify
This command sets whether the legend is on or off (visible or invisible).
Note: The command GeneratePlot must be called to draw the plot with these changes.
legend_on
true
If you want the legend to be on (visible).
false
If you want the legend to be off (invisible).
hwi GetSessionHandle sess;
sess GetClientManagerHandle mgr plot;
mgr GetBuildPlotsCtrlHandle build;
build SetLegend false;
build GeneratePlot;
Keywords
HyperWorks
Tcl
Build Plots
Legend
Modify
