pltIAxis GetRealValue
Gets the real value when the display value is input.
pltIAxis_handle GetRealValue display_value
HyperWorks Tcl Query
This command gets the real value when the display value is input. This command only works properly when the axis is scaled in dB20 or dB10.
- display_value
- A display value that you want to get the corresponding real value of.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot GetVerticalAxisHandle yaxis 1;
yaxis GetRealValue 30;
Success (the real value) or an error message is returned.
Keywords
HyperWorks
Tcl
Axis
Query
