plt3DISurface SetColor
Sets the color of the surface.
plt3DISurface_handle SetColor color
HyperWorks Tcl Modify
The above example refers to colors by name, by RGB value, and by index.
color
A color identifier.
To set the color of an existing surface to red, then white, then blue:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetSurfaceHandle mySurfaceName 1
mySurfaceName SetColor red
mySurfaceName SetColor "255 255 255"
mySurfaceName SetColor 4
None.
