plt3DICurveGroup GetNumberOfCurves
Gets the current number of curves in the curve group.
plt3DICurveGroup_handle GetNumberOfCurves
HyperWorks Tcl Query
A curve group can contain any number of curves. Unlike in the case of a waterfall, the curves are assumed not to be related or to share an orientation.
Returns the number of curves (an integer).
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetCurveGroupHandle myGroupName 1
myGroupName GetNumberOfCurves
Returns an empty string if the value is not defined.
