hwIWindow GetViewControlHandle
Returns the view control handle for the current client.
hwIWindow_handle GetViewControlHandle viewctl
HyperWorks Tcl Query
- viewctl
- The view control handle.
Error
Success (0) or an error code.
View new features for HyperWorks Desktop 2021.2.
Draws the client object.
Returns the client object handle.
Returns the window client type.
Gets the height of the graphics window.
Gets the width of the graphics window.
Gets the window caption used when exporting to HTML.
Returns the window ID.
Returns the offset of a given window.
Returns the scale of a given window.
Gets the export file type for hwlSession_handle PublishSession.
Tests if the window is empty.
Sets the window client type.
Sets the window caption used when exporting to HTML.
Sets the offset of a given window.
Sets the scale of a given window.
Sets the export file type for hwlSession_handle PublishSession.
