hwITemplex Evaluate
Mathematically evaluates a string and returns the result.
hwITemplex_handle Evaluate myexpression, type
HyperWorks Tcl Query
Returns a string indicating the evaluated output of myexpression.
myexpression
The expression to be evaluated.
type
If set to ‘true’, ‘template’, or ‘templex’, the expression is evaluated using the Templex language. Otherwise, it is evaluated as a simple math expression.
To evaluate the mathematical expression 1+sqrt(2):
mySessionName GetProjectHandle myProjectName
myProjectName GetTemplexHandle myTemplexName
myTemplexName Evaluate "1+sqrt(2)" false
None.
