hwISession GetDataFileHandle
Returns the data file interface object for a given file.
hwISession_handle GetDataFileHandle filehandle, datafile
HyperWorks Tcl Query
You need to load a data file (for example, test.dat) in the path specifed before you can get a handle with the above arguments.
filehandle
The user-defined name of the file handle that you want to create with this command. In the examples below, the file handle is "ABC".
datafile
This argument can be of two types:
A variable name that contains the address of the data file that you want to read.
The full path of the data file enclosed within double quotes.
set FileName "D:/temp/test.dat"
hwi GetSessionHandle sessHandle
sessHandle GetDataFileHandle ABC $FileName
Returns: ABC
sessHandle GetDataFileHandle ABC "D:/temp/test.dat"
Returns: ABC
Returns the file handle name if successful.
Returns an error message if the command fails.
