hwIPPTPublishOption SetGraphicsDistanceBottom
Sets the bottom offset of the graphics area.
hwIPPTPublishOption_handle SetGraphicsDistanceBottom p_image_bottom_offset
HyperWorks Tcl Modify
The bottom offset of the graphics area.
To set the graphics distance from the bottom to 20 and change either the width or height, whichever is not the master dimension (as UpdateResolution is true by default).
Opt SetGraphicsDistanceBottom 20
To set the graphics distance from the bottom to 20, but not change the width or height as the update resolution is false.
Opt SetGraphicsDistanceBottom 20 false
Error
Returns success (0) or an error code.
Keywords
HyperWorks
Tcl
Query
