hwIPPTPublish GetClassName
Returns the class name.
hwIPPTPublish_handle GetClassName
HyperWorks Tcl Query
Returns the class name hwIPPTPublish.
Error
Returns success (0) or an error code.
Keywords
HyperWorks
Tcl
Query
View new features for HyperWorks Desktop 2021.2.
Closes the linked PowerPoint file.
Gets the destination type for the published session.
Gets the active open PowerPoint filename.
Gets a list of the Open PowerPoint names published from the session.
Gets the path on the disk for the published session.
Gets the handle which provides the provision to use different options.
Gets whether or not to sync when you publish from HyperWorks Desktop.
Gets whether or not to sync HyperGraph notes.
Publishes the present session.
Saves the linked PowerPoint file to the selected filename.
Sets the destination/location to publish the session.
Sets the active PowerPoint filename.
Sets the path that you define.
Sets whether or not to sync at publishing.
Sets whether or not to sync HyperGraph notes when publishing.
Synchronizes images/animations in a HyperWorks Desktop session.
HyperWorks
Tcl
Query
