hwIObject ReleaseHandle
Used to free this interface object.
object_handle ReleaseHandle
HyperWorks Tcl Query
None.
View new features for HyperWorks Desktop 2021.2.
Returns the class name as a string.
Returns the super class name as a string.
Tests if the given class name is the class or a descendant of the named class.
Casts the supplied object to an hwIObject.
None.
