hwi ListAllHandles
Gets a list of all active handles.
hwi ListAllHandles
HyperWorks Tcl Query
hwi ListAllHandlesView new features for HyperWorks Desktop 2021.2.
Ends automatic handle tracking and releases any handles acquired during handle tracking.
Gets a handle to the current session.
Begins automatic handle tracking.
hwi ListAllHandles
hwi ListAllHandles(c) 2021. Altair Engineering Inc. All Rights Reserved.
