hgtrans control GetFile
Gets the current input file name.
HyperGraphTrans Tcl Query
This command gets the name of file that will be used as an input for the translation process.
Sets hgtrans to read from a MADYMO file called “ANGACC” and then reads back that name.
hgtrans control SetFile “ANGACC”
An error will be reported during translation if the file is not present or not supported.
Keywords
get input file
