amfIMovie CalculateTrackingData
Calculates the tracking data, using the OpenCV tracking functionality, for the markers.
movie_handle CalculateTrackingData speedup
Invokes the OpenCV tracking functionality and runs tracking calculations for all the markers specified as needing recalculation.
- speedup
- The speedup parameter is optional, and has the following acceptable values:
- 0 (Default Value)
- This will result in the value set by amfIMovie::SetSpeedupTracking being used. See section 9.17 for more information on the SetSpeedupTracking API.
- 1-10
- The video resolution will be divided by this number before calculating. A value of 1 will result in no speedup, while a value of 2 will yield the greatest speedup benefit with the safest results. A value which is too high will result in inaccurate tracking results, and higher values yield only marginally better speed.
movie_handle CalculateTrackingData 2
Error
- 1 = HW_Error
- 3 = HW_InvalidHandle
- 4 = HW_InvalidArgs
