PostScript Files from Batch Mode
Batch mode enables you to generate an Encapsulated PostScript plot file from a script without starting the graphical interface for the program.
The plots are output as an Encapsulated file that can be sent to a PostScript printer or viewed using a PostScript viewing utility. The output can be either landscape or portrait.
The Encapsulated PostScript file is created in the directory from which the batch mode is run.
