Model Types
Learn about the different type of models available in HyperStudy.
Beta Preprocessor Model
Use the Beta Preprocessor model to create a parametric connection to a B Preprocessor database enabling you to generate solver input files.
![](../../images/icons/icon_model_bprocessor.png)
- Version
- N/A
- File Extension
- .ansa
- Multi-Execute Support
- Yes
- Response Definition Support
- No
- Registration Steps
- Register a solver script that points to an ansa startup.
- Usability Characteristics
- The FE output path in a .ansa file should be relative. If it is not, you will receive a warning when importing input variables.
FEKO Model
Use the FEKO model to connect to a Feko project, which enables you to automatically detect input variables and run high frequency electromagnetic simulations.
![](../../images/icons/icon_model_feko.png)
- Version
- 2017 or above
- File Extension
- .cfx
- Yes
- No
- Register a solver script that points to runfeko.exe.
- Output responses from Feko are written to the hst_output.hstp file by a custom .lua script. If no .lua script is present, Feko will generate a nominal script which performs a trivial calculation. This nominal script must be modified to request the specific output response of interest from Feko.
Flux Model
Use the Flux model to connect to any Flux 2D and 3D project, which enables you to automatically detect input variables and run low frequency electromagnetic simulations.
![](../../images/icons/icon_model_flux.png)
- Version
- Flux 12.1 or above
- File Extensions
- .F2G
- Yes
- Yes
- Register a solver script that points to flux.exe. For more information, refer to Register Solver Scripts.
- Some Flux outputs (such as curve value extractions) require a post-processing python file to be executed after each simulation. If a python command file is required, it should be specified in the .F2G or .F2HST file. Drag and drop the .F2G or .F2HST file into HyperStudy to connect the model and identify the inputs and the outputs. Once a connection is established, HyperStudy can automatically run as many Flux simulations as requested by the method (DOE, Optimization).
- For information on how to expose Flux model parameters and outputs to HyperStudy by means of a .F2G or .F2HST coupling file, refer to the Flux help and HyperStudy dedicated tutorial.
FluxMotor Model
Use the FluxMotor model to connect to a FluxMotor model.
![](../../images/icons/icon_model_fluxmotor.png)
- Version
- 2018.1
- File Extension
- .fm2hst
- Yes
- Yes
- Register a solver script that points to FluxMotor_Install_dir/Scripts/win/FluxMotors.exe.
- Refer to the FluxMotor help for more information on how to expose FluxMotor model parameters to HyperStudy.
HyperStudy Fit Model
Use the HyperStudy Fit model to import the python based report created by a Fit approach from another HyperStudy session.
![](../../images/icons/icon_model_hst_fit.png)
- Version
- N/A
- File Extension
- .pyfit
- Yes
- Yes
- N/A
HyperMesh Model
Use the HyperMesh model to directly access the HyperMesh database of the model, which enables you to perform easy design parameterization of solver input files.
![](../../images/icons/icon_model_hypermesh.png)
- Version
- Current HyperWorks installation
- File Extension
- .hm
- Yes
- No
- HyperMesh is automatically registered in HyperStudy.
- Input variables are limited to solver interface specific presets and general parameter entities.
- Can be used with any solver script.
HyperView Model
Use the HyperView model to connect to a HyperView session file, which enables you to automatically extract hotspots.
![](../../images/icons/icon_hyperview.png)
- Version
- 2021.1 or above
- File Extension
- *.mvw
- Yes
- Yes
- N/A
- Used as a subsequent step after a numerical analysis.
Internal Math Model
Use the Internal Math model to create input variables that are contained entirely within HyperStudy and do not map to any external applications.
![](../../images/icons/icon_model_internal_math.png)
- Version
- N/A
- File Extension
- N/A
- Yes
- No
- N/A
- Used to link variables between models.
- Used for variables used directly in response expressions.
Knowledge Studio Model
Use a Knowledge Studio model to import the predictive model from a Knowledge Studio session.
![](../../images/icons/icon_model_knowledge_studio.png)
- Version
- 2020.1 or above
- File Extensions
- .kdm
- Yes
- Yes
Register a solver script that points to <...>/Altair Knowledge Works/KS Workstation 2020.1.0/HyperStudy/runKS.bat for Windows and <...>/Altair Knowledge Works/KS Workstation 2020.1.0/HyperStudy/runKS.sh for Linux.
- Verify that the path to the Python executable is valid in the Knowledge Studio installation configuration file, KS Workstation 2020.1.0/HyperStudy/runKS.cfg.
Lookup Model
Use the Lookup model to extract values from a file with known input/output pairs.
![](../../images/icons/icon_model_lookup.png)
- Version
- N/A
- File Extension
- .csv
- Yes
- Yes
- N/A
- The .csv file must be structured so that all of the first N columns are imported as input variables, and all remaining columns are imported as output responses.
- Evaluation of the model with input variables that have no matching row will result in an execution failure.
MotionView Model
Use the MotionView model to directly access the HyperView database of the model, which enables you to perform easy design parameterization of solver input files.
![](../../images/icons/icon_model_motionview.png)
- Version
- File Extension
- .mdl
- Yes
- No
- MotionView is automatically registered in HyperStudy.
- Can be used with any solver script or the have MotionView run the solver defined inside itself.
Operator Model
Use the Operator model to execute a process but not have an associated write operation.
![](../../images/icons/icon_model_operator.png)
- Version
- N/A
- File Extension
- N/A
- Yes
- No
- N/A
- Frequently used in conjunction with linked model resources in order to define the steps of a process flow. A process can be defined as a sequence of HyperStudy models, including Operators, rather than a single model with a single detailed and non-reusable solver script.
Parameterized File Model
A Parameterized File model is a general ASCII text file, which has search and replace substitution for input variables.
![](../../images/icons/icon_model_parameterized.png)
- Version
- N/A
- File Extension
- .tpl
- Yes
- No
- N/A
- A Templex language syntax is used inside of the parameterized file.
- The formatting in the parameterized file is independent of the internal storage.
SimLab Model
Use the SimLab model to parametrically drive SimLab macros, which can be used to automatically mesh and solve FEA problems.
![](../../images/icons/icon_model_simlab.png)
- Version
- 2019.1 minimum
- File Extension
- .js
- No
- Yes
- Register a solver script that points to bin/<platform>/SimLab.bat.
- The FEA solver is run as part of .js script.
- The HyperStudy directory (.hstudy) and the SimLab project directory cannot be the same.
Spreadsheet Model
Use the Spreadsheet model to perform calculations.
![](../../images/icons/icon_model_spreadsheet.png)
- Version
- Microsoft Office
- File Extension
- .xls
- .xlsx
- .xlsm
- No
- Yes
- N/A
- Input variable and output response cells are identified by the user.
- When creating a Spreadsheet model an input variable's value and label can be formatted in two consecutive rows or two consecutive columns. Input variable labels should only contain English characters, or a combination of English characters and numbers. If you do not create a label for a variable, HyperStudy will assign one by default.
- On a Windows operating system, Spreadsheet
models will be brought to the front. HyperStudy
will prevent you from accessing any spreadsheets that you had opened
prior to or after (by double-clicking) starting your current
HyperStudy session.
To access an Excel spreadsheet while running a study with Spreadsheet models, you must explicitly start a new session of Excel.
- Windows platform only
- Support for VB macros
Workbench Model
Use the Workbench model to connect to an ANSYS workbench project.
![](../../images/icons/icon_model_workbench.png)
- Version
- 17.1
- File Extension
- .wbpj
- No
- Yes
- Register a solver script that points to runwb.exe.
- Windows support only
- Input variables are automatically detected from Workbench input parameters.
- Output responses are automatically detected from Workbench direct outputs.
