Demo Browser
The Demo Browser (F7) displays a list of demo models packaged with the software.
Double-click a model to load it in the modeling window. This is a convenient way to access tutorial models.
Discover new features and enhancements.
New to Inspire Form? Learn the basics here.
Start using Inspire Form with our interactive tutorials.
Create 2D sketches, surfaces, and solids.
Perform Feasibility, Blank Fit, and Blank Nesting analyses.
Open any part in Studio to design the die, and import the die face design into Inspire Form from Studio.
Perform tryout analyses to validate die designs.
Review forming outcomes through the Analysis Explorer.
View the glossary or frequently asked questions.
View a list of glossary terms and definitions.
Alternatives are a convenient way to manage design variations within your model.
You can use the Configure toolbar on the Model Browser to activate and deactivate parts. This is called configuring your model.
Context menus contain commands that allow you to edit a selected item, and are available for parts, entities, and tools on the ribbon.
The installation directory is the location where the application was installed.
An instance is a copy of a part that is linked to the original part.
The Model Browser shows all of the objects in your model in a tree structure.
The modeling window, sometimes referred to as the graphics area or window, is where you interact with your model.
Mouse controls are used to pan, zoom, and rotate the model.
In Inspire, there are two basic methods of displaying 3D objects on a 2D plane: perspective projection, which takes perspective effects into account; and orthographic projection, which does not.
A part is a geometric object made up of any combination of solids, surfaces, and curves. It can also be a mesh.
The principal axes or global axes are the x, y, and z axes in the View Rotator.
The Property Editor shows all the properties of a selected object and allows you to edit them.
The ribbon allows you to quickly access tools and standard functions, and is located at the top of the Inspire workspace.
The Screen Capture tool saves an image of your model with a white background.
The Snaps Filter icon
is located in the lower right corner of the application window. It opens the snaps menu.
Standard views are a convenient way to rotate your model to a set camera angle. Top, bottom, front, back, right, left, and several isometric views are available.
The status bar displays model status information and includes the snaps filter and unit system selector.
Use the Unit System Selector to change the display units used in the user interface. (These can be the same or different as the modeling units, which are set in the Preferences.)
The view controls are located in the lower left corner of the modeling window.
When in sketch mode, the Rotate to Closest Principal Axes
icon is replaced with the View Normal to Grid
icon in the view controls.
Use the View Rotator to achieve finer control of rotation than is possible by using the mouse.
Most tools on the ribbon include text prompts beneath the tool or guide bar that explain what to do next. These prompts are a form of user assistance called workflow help.
You have questions about Inspire Form's Feasibility component. We have answers!
Let us guide you through your roadblocks.
You have questions about Inspire Form's Tryout component. We have answers!
Review information about material properties and creating and editing materials.
Learn keyboard shortcuts and mouse controls for common operations.
(c) Altair Engineering, Inc. All rights reserved.
