Global Response Surface Method (GRSM)
The global response surface method (GRSM) is a response surface based approach. During each iteration, the response surface based optimisation generates a few designs. Additional designs are generated globally to ensure a good balance on local search capability and global search capability.
Error treatment and termination
The response surface is adaptively updated with the newly generated designs to have a better fit of the model.
The text log of the GRSM method
================ L O G - FILE - OPTFEKO ================
Version: 14.0.430-24 of 2016-08-22
Date: 2016-08-30 11:36:21
File: dipole_grsm
OPTIMISATION WITH Feko
================= Optimisation variables =================
No. Name Beg.value Minimum Maximum
1 h 2.000000000e+00 1.600000000e+00 2.400000000e+00
2 radius 2.000000000e-03 5.000000000e-04 5.000000000e-03
=================== Optimisation goals ===================
No. Name Expression
1 grsm.goals.impedance_mag73ohm mag(inputimp(impedance(source)))=== Optimisation method: GLOBAL RESPONSE SURFACE METHOD (HyperOpt) ===
On failed analysis: Ignore failed analysis (=1)
Maximum iterations: 50
Random seed: 1
Initial sample points: 4
Points per iteration: 2
Constraint violation tol. (%): 5.0000000000e-01
Constraint threshold 1.0000000000e-04=========== GLOBAL RESPONSE SURFACE METHOD (HyperOpt): Intermediate results ===========
No. h radius grsm.goals.impe Global goal Global best aim
1 2.000000000e+00 2.000000000e-03 8.223708649e+01 9.237086490e+00 9.237086490e+00
2 2.348800000e+00 4.964000000e-03 2.488655725e+02 1.758655725e+02
3 1.678080000e+00 4.942400000e-03 1.120701608e+02 3.907016075e+01
4 2.394880000e+00 9.464000000e-04 3.227940059e+02 2.497940059e+02
5 1.928320000e+00 2.401760000e-03 6.825584105e+01 4.744158945e+00 4.744158945e+00
...================= GLOBAL RESPONSE SURFACE METHOD (HyperOpt): Finished =================
Optimisation finished (GRSM optimiser stopped. Number of analysis reached the maximum allowed number of
50)
Optimum found for these parameters:
h = 1.957379988e+00
radius = 3.243705368e-03
Optimum aim function value (at no. 47): 4.087626847e-02
No. of the last analysis: 50
