Source Data
View the quantities that are available for voltage, current and waveguide sources as well as FEM modal ports.
On the Home tab, in the Add results group, click the  Source data icon.
Table 1. Source quantities.
Quantity Voltage and Current sources Waveguide sources and FEM modal ports
Impedance
Admittance
Voltage
Current
Reflection coefficient
VSWR
SWR
Source power
Power loss due to mismatch
Mismatch loss
Note: The quantities listed are only available for sources on ports. For ideal sources, such as plane waves and electric dipoles, or equivalent sources such as far field and near field sources, source data is not available since these sources are, per definition, not connected to any geometry.
