Result Types
View the result types that can be added to a 3D view or a graph.
The results types are available on the Home tab, in the Add results group.
| Icon | Icon text | Description |
| Far field | The far field results, for example, electric field, gain, axial ratio and RCS. | |
| Near field | The near field results, for example, such as electric field, flux density, SAR and isosurfaces. | |
| Error estimate | Colours the mesh in the 3D view according to the results for the error estimation. | |
| Currents | The currents results such as electric currents, magnetic currents and charges. | |
| Currents | The currents results for wire segments such as electric currents and charges. | |
| Rays | Ray information for a model solved with the RL-GO or UTD. | |
| Source data | The source results, for example, input impedance, reflection coefficient and VSWR. | |
| Loads / Networks | The results for loads and networks, for example, voltage, current and power. | |
| S-matrix | The S-parameter results. | |
| Power | The results for source power, for example, power in the far field and loss power. | |
| RX antenna | The results for the receiving antenna, for example, received power and phase. | |
| RX antenna | The results for the far field receiving antenna, for example, received power and phase. | |
| RX antenna | The results for the near field receiving antenna, for example,received power and phase. | |
| RX antenna | The results for the spherical modes receiving antenna, for example, such as received power and phase. | |
| Probes | The probe data from a cable schematic such as voltage and current. | |
| SAR | The SAR data such as 1g, 10, and volume average. | |
| Optimisation | The optimisation data, for example, individual and global goal and parameter data. | |
| Transmission / reflection | The transmission and reflection coefficients. | |
| Characteristic modes | The characteristic modes data, for example, model excitation coefficient, eigenvalue and modal significance. | |
| Imports + Scripts | Results from imported data and Lua scripts. |
POSTFEKO only enable the icons for results available in the current model or project.
Restrictions on the Display of Data
The result types that can be displayed depends on the view type ( or graph).
- far fields
- near fields
- error estimates
- currents
- rays
- SAR (only when calculated at a specific location)
Cartesian graphs can display all data, except for error estimates and currents on triangles (currents on segments can however be displayed).
Polar graphs can display data that varies according to angle (theta or phi). Only near fields and far fields meet this requirement.
Smith charts can display complex source data such as impedance and S-parameters.
Data can be imported for all graphs provided the data is consistent with the graph type.
| Result type | Cartesian | Smith | Polar |
| Characteristic modes | |||
| Far fields | |||
| Impedances | |||
| Loads | |||
| Near fields | |||
| Networks | |||
| Optimisation results | |||
| Power | |||
| Probes | |||
| Sources | |||
| Parameters | |||
| Transmission / reflection coefficients | |||
| Wire segment data (Charges / Currents / Error estimates) |
