Modifying Multiple Variables
Modify multiple variables on a single dialog.
On the Construct tab, in the Define group, click the
Variable icon. From the drop-down list, select the
Multiple variables icon.
- Click the fields that you want to edit and modify their contents.
[Optional] To view the result of the expressions or test the validity of the
expressions (without closing the dialog), click
Evaluate.
The calculated results are displayed in the Value column.Note: The results are maintained until the next time the expressions are evaluated (the results are not updated automatically when the expressions are changed).
Select one of the following workflows to close the dialog.
- To modify the variables and close the dialog, click OK.
- To modify the variables, but keep the dialog open for further modifications, click Apply.
Figure 1. The Modify multiple variable dialog.
