Solving a Curved Face with Faceted UTD
To solve a model with the faceted uniform theory of diffraction (faceted UTD), you must activate faceted UTD for each relevant curved face.
Use CADFEKO to configure a solver-ready input file for Solver simulations.
View the main elements and terminology in the CADFEKO application window.
CADFEKO has various default settings that you can configure to customise it to your preference.
A number of rendering options are available to ensure that 3D models are rendered efficiently.
Store the unmeshed CADFEKO model and calculation requests to a .cfx file to reopen later.
3D views are used to display and interact with the model. You can zoom, rotate and pan around a 3D model using the keyboard, mouse or a combination of both. You can use a 3D mouse, specify a view or select specific parts of a model. Multiple 3D views are supported.
Define the model unit, variables, named points, workplanes and the model extents for the model.
Create fully parametric and complex CAD geometry using canonical structures and perform Boolean operations on these.
The component library contains an extensive list of common components, such as antennas and platforms.
An assembly is a tool that is used to organise geometry and mesh parts. It allows you to group the geometry or mesh parts in the model tree.
Mesh parts can be manipulated in CADFEKO. Basic mesh editing and fixing capabilities allow triangles to be added, removed and mesh parts to be merged.
Import a CAD (geometry) model or mesh model from a wide range of industry formats into CADFEKO to save time and development costs.
A CADFEKO model can be exported to a variety of industry standard geometry and mesh formats to be used in other applications.
Define field or current data using either far field data, near field data, spherical mode data or PCB current data. Use the field/current definition when defining an equivalent source or a receiving antenna.
Define a medium with specific material properties, import a predefined medium from the media library or add a medium from your model to the media library.
Defined media can be applied to the model in various ways. Some media settings are applied to regions, others on faces and wires. The rules for defining media varies between the different solution methods.
Use a periodic boundary condition (PBC) to analyse infinite periodic structures. A typical application of PBC is to analyse frequency selective surface (FSS) structures.
Create an arbitrary finite antenna array that consists of an array of contributing elements, either with direct feeds for each element or via indirect coupling, and solve with the efficient domain Green's function method (DGFM).
Use the windscreen tools to define a curved reference surface constrained by a cloud of points, normals and optional U′V′ parameters. The constrained surface is then used as a reference to create a work surface where windscreen layers and curved parameterised windscreen antenna elements can be created.
Many electromagnetic compatibility and interference problems involve cables that either radiate, irradiate or cause coupling into other cables, devices or antennas. Use the cable modelling tool and solver to analyse the coupling and radiation.
For a frequency domain result, the electromagnetic fields and currents are calculated at a single frequency or frequency range. When the finite difference time domain (FDTD) solver is used, the frequency must be specified to convert the native time domain results to the frequency domain.
The excitation of an antenna is normally specified as a complex voltage, but it may be useful to specify the total radiated or source power instead. The result is then scaled to yield the desired source power level.
A port is a mathematical representation of where energy can enter (source) or leave a model (sink). Use a port to add sources and discrete loads to a model.
A source is used to excite or illuminate the model and cause current to flow.
Complex feed networks can be simplified by including them as a circuit representation using general network blocks.
Obtain multiple solutions for a single model using multiple configurations. Multiple configurations remove the requirement to create multiple models with different solution requests.
Before running the Solver, define the output requests.
Use an infinite plane or half-space to model a ground plane efficiently. The number of triangles in the model is reduced as the ground plane is not discretised into triangles.
During the design process, the development of a model can introduce a range of issues that can lead to a non-simulation-ready model. Use the validation toolset to verify that the model is simulation-ready or to search, detect and flag discrepancies.
The default solver used in Feko is the method of moments (MoM) - surface equivalence principle (SEP). Whether a solver is specified per model, per face or per region, depends on the solver in question.
Define and exploit the symmetry in the model (where applicable).
General solver settings are available that relate to geometry tests and data storage precision.
Advanced solver settings are available to reduce the memory footprint or speed up a solution for specific types of models.
For large models, the simulation time can be decreased if the solution coefficients are saved during the solution phase.
The MoM is a full wave solution of Maxwell’s integral equations in the frequency domain.
The multilevel fast multipole method (MLFMM) is a current-based method applicable to electrically large structures.
When using either the MoM or the MLFMM, you can specify the integral equation method to be applied to a face to obtain either faster iterative convergence or higher numerical accuracy.
The adaptive cross-approximation (ACA) method is a fast method, similar to multilevel fast multipole method (MLFMM). The method improves the solution of complex method of moments (MoM) problems using considerably less memory and run-time.
finite element method (FEM) solver method is a volume meshing technique used to model electrically large or inhomogeneous dielectric bodies.
The physical optics (PO) solver method is an asymptotic high-frequency numerical method based on currents. Use the method in instances where electrically very large metallic or dielectric structures are modelled.
The ray launching geometrical optics (RL-GO solver method is a ray-based method that models objects based on optical propagation, reflection and refraction theory.
The uniform theory of diffraction (UTD) is an asymptotic high-frequency numerical method. The method is typically used for electrically extremely large PEC structures.
To solve a model with the uniform theory of diffraction (UTD), you must activate UTD for each relevant flat face.
Solve a cylinder with the uniform theory of diffraction (UTD). The cylinder can either be a finite, semi-infinite or infinite, depending on the termination type of the start cap and end cap.
A number of optional settings are available when using the uniform theory of diffraction (UTD) to solve a face or faces.
A number of optional ray contribution parameters are available when using faceted UTD to solve a face or faces.
The finite difference time domain (FDTD) solver is well suited to modelling inhomogeneous materials and simulation of wideband antennas.
The dielectric surface impedance approximation is solution method that can be applied to homogeneous, lossy dielectric regions. Use the solution method to compute SAR values for an homogeneous phantom.
Specify the command-line parameters for the Feko components.
CADFEKO has a collection of tools that allow you to quickly validate the model, for example, perform calculations using a calculator, measure distances, measure angles and export images.
View the icons that are found in the model tree.
View the icons that are found in the details tree.
View the files associated and generated by CADFEKO.
