Create analytical curve to be used either as a building block for constructing geometry
or as a wire. Analytical curves are parametric definitions (in “t”) that define the path in
three coordinate systems.
The derivatives of the expressions are required and need to
exist over the entire path. If dividing the derivative by zero, the definition is not
accepted. An alternative would be to calculate the points in the scripting environment and
create a fitted spline.
On the Construct tab, in the Create curve group, click the Analytical curve icon.Tip: Press V,6 to use the shortcut key.
Table 1. Method 1: Cartesian
Parametric interval |
Interval over which the analytical curve is parametrically defined. |
Cartesian description |
The description of the curve using the Cartesian coordinate system. The U, V
and N dimensions as a function of variable t. |
Table 2. Method 2: Cylindrical
Cylindrical description |
The cylindrical description of the curve in the ρ,
θ and ϕ dimensions as a function of
variable t. |
Table 3. Method 3: Spherical
Spherical description |
The spherical description of the curve in the r, θ and
ϕ dimensions as a function of variable t. |
