Microstrip Filter on an Infinite Substrate (Planar Multilayer Green's Function)
Model the microstrip filter using an infinite substrate and planar multilayer Green's function. Use a voltage source on a microstrip port for the source.
Modify the finite element model from Microstrip Filter on a Finite Substrate (FEM) to use an infinite substrate. Remove the line ports.
