S-Parameter Coupling in a Stepped Waveguide Section
Calculate the transmission and reflection for a stepped waveguide transition from the Ku- to X-band. Use two solver methods, the method of moments (utilising waveguide ports) and the finite element method (utilising FEM modal ports).
The waveguide consists of a Ku-band section and an X-band section. Only the H10 mode with cutoff frequency, GHz is considered.
- a = 15.8 mm
- b = 7.9 mm
- a = 22.9 mm
- b = 10.2 mm
Calculate S-parameters from the cutoff frequency to 15 GHz.
![](../../../../images/feko/example_guide/EG_E02_waveguide_step/intro.png)
Figure 1. 3D view of the waveguide step in CADFEKO.
