View the status of the current run, as well runs for the current model that have not yet been viewed. To see all past
runs, you need to view the run history.
Run an casting analysis to minimize defects and prevent manufacturing
problems.
Process Parameters
Define the parameters for a basic, gravity, high pressure, or low pressure casting process.
Run Options
Choose whether to run jobs in sequence or in parallel.
Run Analysis
Define and run a filling analysis, solidification analysis, or both.
Use Advanced Meshing with SimLab
When running an analysis, automatically export your model and perform advanced meshing in SimLab.
Run Status
View the status of the current run, as well runs for the current model that have not yet been viewed. To see all past runs, you need to view the run history.
Run History
View, sort, open, and delete past runs for the current and previous models.
