Cumulated Probability Density Function (CDF)
- all prediction planes and all horizontal layers
- all horizontal prediction planes
- prediction planes and surfaces only
- currently active horizontal prediction plane
- zoomed area of the currently active horizontal plane
![](../../../../../images/winprop/user_guide/proman/results/graph_probablility_cdf.png)
Figure 1. Example of a cumulated probability density function of power prediction in an urban environment.
100% - Cumulated Probability Density Function (100% - CDF)
Besides the standard cumulated probability density function ProMan also offers the possibility to determine the 100% - CDF for each type of simulation result. This option can be chosen from menu or from toolbar. In the corresponding submenu the user can select whether the 100% - CDF plot shall consider all prediction planes and all horizontal layers, prediction planes and surfaces only, all horizontal prediction planes, the currently active horizontal prediction plane or the zoomed area of the currently active horizontal plane.
The following example shows a 100% - CDF plot of a maximum downlink SNIR prediction in an indoor environment.
![](../../../../../images/winprop/user_guide/proman/results/example_100_cdf.jpeg)
Figure 2. Example of a 100% CDF plot.
