Altair WinProp  2021.1 Documentation
  1. Home
  2. ProMan
    The ProMan component includes wave propagation models for different scenarios and network planning simulators for various air interfaces.
  3. Results
  4. Display of Results
  • Release Notes
  • Get Started
  • Examples
  • Introduction to WinProp
  • Typical Workflow in WinProp
  • WallMan
  • TuMan
  • AMan
  • ProMan
  • Methods
  • Main Applications
  • Optimization (OptMan)
  • Connectivity Manager (CoMan)
  • WinProp Utilities
  • Appendix
Index
  • Release Notes
  • Get Started
    The WinProp Getting Started Guide contains step-by-step instructions on how to get started with WinProp.
  • Examples
    The Altair installation directory contains a collection of examples that shows you WinProp concepts and essentials.
    WinProp is a complete suite of tools in the domain of wireless propagation and radio network planning. With applications ranging from satellite to terrestrial, from rural via urban to indoor radio links, WinProp’s innovative wave propagation models combine accuracy with short computation time.
    View the typical workflows when working with propagation simulations in specific scenarios, how to add a network planning to a propagation simulation, include a receiver pattern, set up a time-variant scenario, include multiple-input multiple-output (MIMO) at both the base station and the mobile station, connectivity analysis of sensor networks and optimization.
  • WallMan
    The WallMan component offers a convenient facility to generate and edit vector building databases.
  • TuMan
    The TuMan tool enables you to generate and modify tunnel scenarios.
  • AMan
    Use AMan to generate, edit and analyze a single antenna. Superimpose multiple antennas radiating similar signals to determine the actual antenna pattern while taking into consideration the local environment.
  • ProMan
    • Introduction to Propagation Manager (ProMan)
      Predict path loss between transmitter and receiver with ProMan. Perform network planning including the wireless standards (the air interfaces) and including multiple transmitters/receivers (multiple base stations).
    • Propagation Projects
    • Network and Base Station Planning Projects
    • MIMO Analysis Through Post-Processing
    • Results
      • Display of Results
        • Open
        • Move
        • Zoom
        • Legend
        • Additional Channel Characteristics
        • Multi-Layers
        • Time-Variant
        • 3D View
      • Modification of Results
      • Evaluation of Results
      • Analysis of the Radio Channel
        Additional channel characteristics like channel impulse responses, spatial channel impulse responses and angular profiles can be displayed for user-defined locations in separate graphs.
      • Measurements
        The most important criterion to measure the performance of a prediction model is the accuracy. The accuracy of a prediction models can be analyzed by comparing simulation results with measurements.
      • Types of Results
        View the available result types and the corresponding file extensions.
    • Addenda
  • Methods
    WinProp includes empirical and semi-empirical models (calibration with measurements possible), rigorous 3D ray-tracing models as well as the unique dominant path model (DPM).
  • Main Applications
    In WinProp various air interfaces and applications are pre-defined: broadcasting, cellular, wireless access, WiFi, sensor networks, ICNIRP and EM compliance.
    The OptMan component allows the automatic optimization of orientations of antennas in cellular networks to achieve various targets.
    The CoMan component allows the simulation of the reliability and connectivity in wireless mesh / sensor networks.
  • WinProp Utilities
    The WinProp utilities consist of the Launcher utility and the Updater.
  • Appendix
  1. Home
  2. ProMan
  3. Results
  • Release Notes
  • Get Started
  • Examples
  • WallMan
  • TuMan
  • AMan
  • ProMan
  • Methods
  • Main Applications
  • WinProp Utilities
  • Appendix
Index
Display of Results
  • Open
  • Move
  • Zoom
  • Legend
  • Multi-Layers
  • Time-Variant
  • 3D View
