Terrestrial Transmitters
Tools for adding terrestrial transmitters are given.
The WinProp radio network planning tool allows you to define a specific network configuration comprising the terrestrial transmitter segment. Based on the accurate prediction of the terrestrial transmitter radio channels by using a deterministic ray-optical (or an empirical) wave propagation model the coverage performance of the individual transmitter or the defined network is evaluated.
- Add a new transmitter with the symbol
- Enable / Disable a transmitter with the symbol
- Delete a transmitter with the symbol
- Edit a transmitter with the symbol
- Move a transmitter with the symbol
- Change horizontal orientation of a transmitter with the symbol
