Drawing a Floor
Define the floor of the building. The concrete floor should be large enough to be underneath the entire building, and includes an outdoor sitting area.
Verify that the X/Y window is active, or activate it by
clicking in it.
The X/Y symbol in the top-left of the window is red when the window is active.
Confirm that the third coordinate (Z value) is at 0 m using one of the
following workflows:
- On the View toolbar, click the
3rd Coordinate Settings icon.
- On the Display menu, click
Show 3rd Coord Dialog.
Figure 1. The 3rd Coord Settings X/Y View dialog.
- On the Edit menu, click Default Values.
Specify the material properties for the floor.
- Under Material Properties, from the Material Properties of new Walls drop-down list, select Concrete; thickness: 20 cm.
- Click OK to close the Default Values for New Objects dialog.
Create the floor in the X/Y window using one of the following workflows:
- On the Objects menu, click Enter Basic Objects > Enter Rectangular Objects.
- On the Objects toolbar, click the
Add Rectangular Objects icon.
- Press F8 to use the keyboard shortcut.
- Click twice in the 2D view to specify a corner.
- Click again in the 2D view to specify the last corner.
Exit the draw mode using one of the following workflows:
- On the Objects menu, click Select Objects > Select Single Object (Mouse).
the
Select Object icon.
- Press F10 to use the keyboard shortcut.
