Search and Filter
Search objects and automatically filter the results to only display the objects that contain the search string. You can also filter by object type.
Note: This only applies to the World and Lights tabs.
  1. Press Ctrl+1 to open the Model Browser.
  2. Click to open the Search and Filter toolbar.
  3. Optional: To control your search, click , and then click one or more of the following options:
    • Match Case
    • Whole Names Only
    • Use Wildcards
  4. In the text field, enter a search string.
  5. Optional: Click the pull-down menu and select the type of objects to filter.
Only the objects that match the search string and selected object type are displayed in the Model Browser.
Tip: Reset the search by deleting the search string and setting the filter to All.
