Manually copy a prepared model file and queue it on a remote jobs server.
This procedure is required to run a job on a remote server that is not an Altair
PBS server.
Click the Run group label to display run options.
Select Manual Remote.
Set up and run an analysis using the Run Analysis
window.
The
Run Status window appears.
Right-click on the run name and select Open the Run
Folder.
Copy the run file and manually submit it to your remote job server
queue.
When the job has been run, copy the set of result files to the Inspire Extrude run history folder on your local computer.
Note: The run history path is defined in the Preferences under Run
Options.
Click the satellite on the Analyze icon to open the
Run Status window.
Right-click on the name of the run and select View
Results.
