Simplifying Geometry
Use the Simplify tool to plug holes and pockets and to remove imprints, rounds, fillets, holes, and pockets.
Remove Imprints
Find and remove imprints from a model. An imprint is an edge or a point that appears on a surface that can be removed without changing the underlying integrity of the surface, such as scratches or trimmed points.
  1. On the Geometry ribbon, select the Simplify > Imprints tool.
    By default, all of the imprints in the model are selected and highlighted red. The total number of imprints found is displayed above the Imprints tool.
  2. Remove imprints.
    • To remove all selected imprints, click Apply on the guide bar.
    • To remove an individual imprint, click a selected imprint.
    Figure 1. Removing Imprints
Tip:
  • It is recommended that you remove imprints before applying other geometry simplification tools.
  • To review each selected imprint located by the search, click and on the guide bar.
  • Some geometry tools automatically detect relevant features when the tool is opened. You can disable this behavior in the Preferences under Inspire > Geometry > Autofind.
Remove Rounds and Fillets
Find and remove both round (convex) and fillet (concave) surfaces.
The Rounds tool allows you to select a round or fillet and find all that are larger, smaller, or similar (±5%) in size. It will also attempt to identify chains of rounds or fillets, although these chains may not be removed successfully all at once. In general, it is best to remove small fillets first, then larger fillets, then rounds. When you get to a point where you cannot remove any more, it is time to use other modeling tools and strategies to complete the geometry simplification.
  1. On the Geometry ribbon, select the Simplify > Rounds tool.
    By default, all of the rounds/fillets in the model are selected and highlighted red. The total number of rounds/fillets found is displayed above the Rounds tool.
  2. On the guide bar, select whether to find Rounds, Fillets, or All.
  3. Optional: Click to define settings used to find and select rounds/fillets of a specific size.
  4. Remove rounds/fillets.
    • Remove all selected rounds/fillets by clicking Apply on the guide bar.
    • Remove individual rounds/fillets by clicking a selected round/fillet.
    Figure 2. Removing Rounds and Fillets
Tip:
  • To review each selected round/fillet, click and on the guide bar.
  • If there are several contiguous rounds or fillets, double-click one to select the entire chain. Selecting an adjacent round/fillet will add to the chain. When removing a round/fillet that is part of a chain, the entire chain will be removed.
Remove Holes and Pockets
Find and remove holes and pockets, and find raised areas such as lettering.
The Holes tool allows you to select holes or pockets and find all that are larger, smaller, or similar (±5%) in size. It will also attempt to identify chains of connected holes or pockets by searching upward, toward the outer face.
  1. On the Geometry ribbon, select the Simplify > Holes tool.
    By default, all of the holes in the model are selected and highlighted red. The total number of holes found is displayed above the Holes tool.
  2. Optional: On the guide bar, click to define settings used to find and select holes of a specific size.
  3. Remove holes.
    • To remove all selected holes, click Apply on the guide bar.
    • To remove an individual hole, click a selected hole.
    Figure 3. Removing Holes and Pockets
Tip:
  • To review each selected hole located by the search, click and on the guide bar. Clicking a selected circle removes it, and the view automatically zooms in on the next selected hole.
  • If there are several contiguous holes or pockets, selecting an adjacent hole/pocket will add to the chain. When removing a hole or pocket that is part of a chain, the entire chain will be removed.
Plug Holes and Pockets
Find holes and pockets, and plug them by filling the area with a new part.
The Plug tool will attempt to identify chains of connected holes or pockets by searching upward, toward the outer face.
  1. On the Geometry ribbon, select the Simplify > Plug tool.
    By default, all of the holes and pockets in the model are selected and highlighted red. The total number of holes/pockets found is displayed above the Plug tool.
  2. Optional: On the guide bar, click to define settings used to find and select holes/pockets of a specific size.
  3. Remove holes.
    • To plug all selected holes or pockets, click Apply on the guide bar.
    • To plug an individual hole or pocket, click a selected hole or pocket.
Tip:
  • To review each selected hole or pocket located by the search, click and on the guide bar. Clicking a selected hole/pocket plugs it, and the view automatically zooms in on the next selected hole or pocket.
  • If there are several contiguous holes or pockets, selecting an adjacent hole or pocket will add it to the chain. When plugging a hole or pocket that is part of a chain, the entire chain will be plugged with a single part.
Simplify Tool Settings
Find Larger
Find features larger then the currently selected feature.
Find Smaller
Find features smaller then the currently selected feature.
Find Similar
Find features similar (±5%) to the currently selected feature.
Find Options
Rounds & Fillets
Radius
Specify a range for the radius used to find features.
Holes & Plugs
Size
Specify a range for the diameter used to find features.
Simplify Tool Keyboard Shortcuts & Mouse Controls
To do this Press
Select feature Left Mouse Click
Deselect feature Ctrl + Left Mouse Click
Deselect chain Ctrl + Double Click
Exit tool Esc
