How do I Define (time) Variable (HTC) Heat Transfer Coefficient?
  • In this example, we are going to change heat transfer coefficient (HTC) between pocket and die. Once you export solver deck, BC at pocket die will be similar to one shown below.
  • Here Heat transfer coefficient at wall is contact = 3000 W/m^2-deg C
SolidFluidInterface Pocket1_die {
HeatTransferCoeff = 3000
ContactBCName = "Die_Pocket1"
X_Velocity = 0
Y_Velocity = 0
Z_Velocity = 0
#Material = AA6060
  • Add function block to define variable HTC after MATASSIGN data block
BEGIN FUNCTION
EXPRESSION htcpocket "{x y z t} {htcpocketf $x $y $z $t}
END
htcpocket = name of expression
htcpocketf = name of TCL function. This is defined in separate TCL script file.
  • Use express name in BC packet as shown below
SolidFluidInterface Pocket1_Die {
HeatTransferCoeff = htcpocket
ContactBCName - "Die_Pocket1"
X_Velocity = 0
Y_Velocity = 0
Z_Velocity = 0
#Material = AA6060
  • Write TCL function to define HTC and save the fine with name VariableHeatTransfer.tcl
proc htcpocketf {x y z t } {
#default value of HTC
set convCoeffi 3000.0;
if { $t <= 0 } {
# HTC at 0th min
} elseif { $t >= 300 } {
#HTC after 5 mins
return $convCoeffi
  • Open.hx file and source TCL script file using following command
# Set environment variable for number of CPUs
set ::env(OMP_NUM_THREADS) 1
set ::env(MKL_NPROCS) 1
set ::env(MP_SET_NUMTHREADS) 1
set: ::env(P_NUMBER_OF_THREADS) 1
set :env(MLIB_NUMBER_OF_THREADS) 1
source VariableHeatTransfer.tcl
