Limitations for SimSolid Analysis
Limitations for SimSolid vs. Optistruct analysis.
Inspire users should be aware of the following limitations when running a SimSolid analysis vs. an OptiStruct analysis:
- Run Part Analysis on the Motion ribbon is not supported
- Multiple boundary conditions (loads, supports, displacements, etc.) can’t be placed on the same feature in the same load case
- Boundary conditions can’t be placed on imprinted points
- Supports at a point must be fixed so that there is no translation or rotation in any direction
- Joints, screws, and spot welds are not supported
- Fastener pretension and stiffness attributes are not supported
- User-defined systems are not supported
- All runs are local sequential
- There is no run history
- Remote loads do not animate with the results
- Reaction forces cannot be extracted
- Undo does not work on deleted results
