Print Part
Select parts to print and assign materials.
- On the ribbon, click the Print3D tab.
Click the Print Part
icon.
- Select a part in the modeling window to prepare it for 3D printing.
- Assign a material to the part in the microdialog.
- You can view the Materials Database and create your own
materials by clicking the
icon on
the microdialog. - When using the Print 3D module, materials should only be assigned or changed using the Print Part tool. Assigning a material using the part context menu or the Property Editor will instead assign an Inspire structural material, which should be ignored.
