Set up and run an additive manufacturing, porosity, or thinning analysis.
Preapare and run an additive manufacturing simulation, and export a file for 3D printing.
Discover new features and enhancements.
New to Inspire? Learn the basics here.
Start using Inspire with our interactive tutorials.
Create parametric sketches, geometry, and PolyNURBS with construction history and variables.
Set up your model and run a structural analysis or optimization.
Set up and run a motion analysis, plot the results, and export the results.
Select parts to print and assign materials.
Configure the 3D printing bed. You can select a default printer or choose from several standard printers.
Orient the part in relation to the printing bed. You can orient the part to a surface, or to achieve the maximum or minimun build height.
Create, designate, and partition supports required for 3D printing.
Examine the part in layers to validate its geometry before 3D printing.
Export a file containing the prepared part and/or supports for 3D printing.
Run a additive manufacturing analysis, then view and plot the results.
Define preferences for 3D printing.
Set up and view the results of a simple porosity analysis for casting.
Set up and view the results of a simple thinning analysis for stamping.
View the glossary, frequently asked questions, and errors and alerts.
Learn keyboard shortcuts and mouse controls for common operations.
